Today I pulled one of my street seats out of the attic and put it in the car. There is no way I want to sit like that! Even if modifying the pan reduces the stifness it gives the chassis, my seating position takes precedence. I have the TCP X-brace and whenever the car has slicks it'll have a roll bar installed so I already have some good lateral support.
I wanted to cut further up the trans. hump and attempt to re-create the contours with the patch. After an hour looking at it I decided it would be way to much work for something that won't be seen when the seat is in. I'm not Jesse James and I don't have an English wheel (nor a Nazi fiancee freak either).
So straight sides it will be:
Once cut out I had to flatten the pan out and make a new bend further out because it needs to be wider when mounted lower down:
I trimmed the downward pointing flange and fit/welded it to the base:
Took out 1.5":
I then made pieces like this for the sides and plug welded them in from the backside and filled/ground the front:
Phew, it still fits in the car...
Now that I've hacked out most of the structure that gives this piece strength, and is the reason why I did the convertible pan, I now have to figure out a way to add some strength back. I'll probably build/weld a framework to the underside before it goes into the car for good.
