any pointers on how to remove rear window trim 67 coupe
the trim on the sides it held on with screws and is very easily removed after the screws are out. The upper and lower trim is like Bill said, use the same type of clips as the front windshield. The lower seems to be tricky IMO. I have removed a few and the lower can bend very easy so take your time.
if you are planning on replacing the gasket, take a utility knife & cut the top "flap" of the rubber that is between the glass & trim off first. makes it MUCH easier to get to the clips to release the trim.
Mine came off real easy, but the new stuff was a biotch to get back on. It kinda depends if you want to reuse it. I got some NOS since mine was so messed up and it was a bugger to get on without banging it up!
