JRANGER
Had a couple questions on a sub panel.
First.....Its a fuse panel, old glass type 60 amp box. 3 circuits currently connected.
1 feeds my garage door opener and a single light and electrical outlet.
1 feeds a single electrical outlet.
1 feeds 6 lights and an electrical outlet
This sub panel is ran off a dual 30 amp breaker from my main panel. It has 2 Sets of 14 gauges (GRAY) wire ran into the sub panel and twisted into a much larger wire the feeds the main.
Is this safe? How many amps are running with this setup?
Should i replace the box? Can i run 220v from this fuse panel?
This is a22x46 garage and i need to add more lighting or well really just replace the fixtures with shop lights.
I want more outlets and 220v for a welder and such. More then likely just as needed but i may also get 220v compressor upgrade at sometime.
Thanks for the help....
