66gt350
the '70 up C4's are the most desired. They have a different valve body and a larger input shaft. A properly built C4 can take a lot of punishment.
"stangg" said:The lifter bores on the 5.0 roller blocks are taller than the pre '85 blocks. The stock Ford roller lifter won't work in earlier blocks... plus there probably isn't any provisions to install the spider retainer. You would probably need to go with aftermarket roller lifters.
"sigtauenus" said:You lost me here.
Why would you be buying any internal parts? I thought the engine was just rebuilt?
"66gt350" said:Just one more thing not to forget: Depending on what roller cam is in the engine, you'll probably have a different firing order than your original 302.
Got it, the Cam is an E303 and has the same firing order as a 351. When i went to look this up online all the info pointed at this cam being designed to go with a 5 speed transmission, I have the C4, will this be a problem? I guess I'm confused as to how a Cam and Transmission can be specific to one another.
"66gt350" said:It don't matter if it's a C4 or T-5. The car will run just fine. With a carb, that's a nice cam.
If you ever go to efi, then it will be time to ditch that cam. That cam results in the dreaded idle surge. It's just radical enough that the stock computer can't compensate. It will run rich then lean then rich then lean...etc...going from 1500 rpms down to 500-600. It will finally drop down far enough to die. That's the cam that I have in my fastback, and it took a long time messing with the computer to get it to idle and not stall at stop lights!!
"gotstang" said:157t is most common for car C4s. The 157t 50oz flexplate is available from autozone for ~$50 or bulkpart.com for ~$22 since Ford used them on the 255ci V8 Mustangs around 1980.
The 164t 50oz flexplate might also be available cheap, if a 1988 F250 351W/AOD flexplate would work?
