DougG69
Ok, having gotten some good advice on testing equipment in another thread, I thought it best to start a new one to ask a few questions about the actual wiring harness itself.
I dug out my spare harness to familiarize myself with it a little since I'm still waiting for the car to get back home from paint (2 more weeks, the paint guy said). When looking at the fuse block, I noticed there was a large opening with a single terminal marked ACCY POST [see arrow (1) in pic below].
It has the black wire with green stripe connected to the back, which according to the wiring diagram should feed from the accessory position on the ignition switch. Could I run a fuse tap there for accessory power? Or otherwise splice into or even re-route the black/green wire to a terminal block if needed?
Also, I noticed an empty space where it looked like a fuse could go, but there were no terminals [see arrow (2) in pic above]. Reading horizontally, below the opening, it says 14A WARN LPS. Reading vertically, along the right side of the opening, it says 14A HEATER. So I guess this is a two-parter:
a) Is there something missing there?
b) If so, is it the fuse for the warning lamps or the heater?
Thanks in advance for any info - Doug
