So I thought I would try to post the agonizingly slow process and I found out I have almost zero pictures. So I'll post what I have. I bought this car when I was 18 back in the summer of 2001 after much help from many of you back at another forum. It was an I6, C4 bare bones nothing special coupe, but it was mine! The first drive was a bit hairy. I didn't know what manual brakes and manual steering were and almost rear-ended a couple of cars. Oops. To top it off, I didn't bother to register or insure it, just threw an old set of plates on it and off I went! It looked decent and I knew it needed some work but I quickly found out what a piece of crap it really was. My mechanic couldn't put it up on the lift because the TB's and front frame supports were shot. When I pulled the carpet completely out I saw that the backing was holding the rust together. Big, BIG holes in the floors. Oops. I bought a welder and taught myself how to fix floors and frame supports and did a damn shitty job of it. But it was more solid than before. It felt like success. So after a few summers of cruising around feeling like a million bucks, It looked like this:
That was around 2004. I decided I wanted to attack the rusty cowls and started tearing it down again.
And big surprise, I found lots of rust.
The cowls were the main problem I wanted to fix and luckily the pass side was salvageable
but the drivers side was not
Unfortunately, that is where my pics end. I'm sure I have more somewhere but I need to go digging. This doesn't show the replacement of the cowl (which looks ugly), pulling the motor and trans, installing the 5.0 and T5, swapping the suspension for the front discs and 9" from a Mach 1 or the most recent dissassembly for prepping for bodywork. So I have a lot to go find. But this is a start. And I know its ugly.... but its mine.
