"Horseplay" said:How are you going to be on hood clearance? I've seen quite a few 351 block installs that left little to no room even once a drop-base air cleaner was installed. It appears from the pictures you will be alright but you might want to measure that up before deciding to shim up the engine. You can relieve the two outer humps on the towers a bit for added room. Cut 'em flat and weld in a patch plate to gain a half inch or so either side.
"Mach1Mark" said:You had to notch the shifter opening? Is your trans support slotted as well as your motor mounts?
