I did some searching and did not find any information. Simple enough I just want to remove the drivers door panel. But to do that I need to remove the window and door handles. I know that they are held on by a clip, I believe on the opposite side of the handle. But how do you remove the clip? With a hook and just pull it out? Or is there a removal tool?
I am hoping that something inside of the door is loose and can be tightened. The drivers door makes a funny noise when going over bumps or sometime just opening the door.
