You should probably let them know it is not a stock Ford cast blockI spun the old 289 engine to 7,500 for 6 years before it went boom. This engine has a 302 block and bottom end. It’s limited by the 66 OE 289 heads. I’m spinning this one to 7,700 so it’ll last. It’s built to turn 8k+![]()
If people READ the thread, they'd know thatYou should probably let them know it is not a stock Ford cast block
Yes, yes it is and...it's spectacular!Bet that engine is screaming at that rpm. Yikes!
Next MaySo when is race day?
Yep, it burns gas and rubber.Is that the new hybrid engine set-up?
Lots of laps in the sim.I sure hope you did something this off-season for a driver mod. That car deserves it.
