Should come as no surprise
If nothing else I am consistent in this one area. I will change course. A lot.
I don't think I discussed this here so here goes. Likely going a new path with the truck (1952 F1). Everything so far on this build has been modern tech resto-mod updating. Everything except the powerplant. That was to be old old school. Getting lucky and finding the '30 Model A has had me do nothing but rethink all this ever since. While I do have a second flathead engine I could rebuild for the Model A, it sure seems like the obvious path would be to put the completed blown flattie in it and do something else with the truck. A fully polished blown flathead belongs in hoodless rod like the coupe. For the truck something on the other end of the spectrum. Something modern, current. Rather than spend another $20k or so on a second flathead build wouldn't it make more sense to buy something turnkey?
I'm in the process of pulling the cab off the frame so I can finish all the little chassis stuff (brake lines, etc.), bodywork the frame and paint it. Be the opportune time to do the heavy lifting part for the new direction I am charting. That being to do the engineering and mounting parts fab for a different engine and trans combo. Cutting the suspense, I'm thinking 7.3L Godzilla with a new automatic trans behind it.
Looking at it from an expense perspective I'd be saving a fair amount over building a new engine and trans for the coupe. Everything for the current truck plan would swap into the coupe so nothing really wasted. From a time angle, It wouldn't take much to reconfigure for the new driveline. With the cab off it would be pretty quick and easy actually. It would require me to likely have to cut the floor a bit and fab a new tunnel/cover but at this point that kind of work is pretty straight forward for me now. The more I type this out the more it makes me want to go this route. Some may recall the initial thought when I got the truck was to go twin turbo coyote but I caved to the idea nostalgia of the flathead. Well, here we are pretty much full circle. The nice thing is the 7.3L Godzilla fits better than a Coyote would have. In fact, it leaves room for those turbos...???? SOB!
So let's talk this out. What do you guys think? I'm missing this season one way or another with the truck this year. At best if I stayed the course I might get it driving but never painted. Either way I would be painting this winter or more likely late spring when it gets warm again.
Let's hear it!
Maybe you could get a package deal at the Illinois State Hospital for the mentally deranged.
I like the changed direction. The Godzilla package can be purchased at a relatively cheap price, crate motor speaking, and they belong in trucks. I like the idea of the flathead being more on display in the 30 Model A. I approve, you may now continue.
The 7.3 sounds like it'd be an awesome fit in the truck. I know they originally had some crazy tall intake on the engine stock that made it more difficult to swap into cars.
Teresa must be on the verge of a complete mental meltdown.
Oh, have times changed. She is almost supportive these days. Doesn't ask about the money anymore. Urges me to make time to work in the garage. Wait a minute. Uh oh...
Nah. She's cool with it all. Wasn't exactly keen on the Model A but has come around once I showed her some concepts I sketched up. I'm sure she'd be all in on the Godzilla in the truck. It would mean a change to automatic. Factory new car reliability. AC and other creature comforts would make time in it more enjoyable and she could actually be the driver. Afterall, I sold her on it in the first place as being "her" cruise night ride.
I've got a line on a deal that is really good. That's what got me headed this way.
Let's hear it!
New guy here & not knowing everything i say kill 2 birds with one stone . Put that flathead where it goes . Where it can be seen .That 52 will look just fine with a late model drivetrain in it .
Keep reminding your self ,new paint won't make it faster
Lots of old threads being revived with the influx of newbies. Guess it is a good way to help everyone get acquainted.
The latest on my projects is that the Coupe is getting the fully polished blown flathead and I have put together a really nice Coyote engine for the F1. Coupe gets the T5 I rebuilt and the truck has a very fresh 6R80 to go between the 5.0 and the 9". The Coupe has a brand new Winters quickchange to turn the rubber.
I'm in the midst of a nightmare move south at the moment but when the dust settles I will have a new to me 40x60 shop in which I can finally get back to making things run again.
I have a godzilla swapped 1937 ford with a comp stage 1 cam. The thing is an absolute monster and at idle you'd never even know it had the cam. I have the holley oil pan kit and accessory drive and love it.
A few years back I spent $5600 getting a 331 built, that was with me supplying the cam, lifters, block, heads and intake. I paid $5500 a piece for brand new godzilla take outs.
What are you useing for eng control?
Im running a tkx transmission with a ford manual control pack. Despite what comp said about not requiring a tune with the stage 1 cam that was bs. At wot it would hit torque control mode and drop to zero degrees timing at 5k rpm.
You get a tune in it to fix that ? I ask about your control because when i put a 5.4 DOHC & 6R80 IN my 97 F150 about 6/7 years back all i could find was for straight shifts. Finally found Power By The Hour in Florida & they hooked me up .
I did get a tune to fix that, basically the ecu was seeing more torque than it was desiring so it was trying to reduce it through timing.
I have hptuners for it but am not sure ill ever master drive by wire tuning. I can tune my 03 cobra but its a whole different beast with drive by wire. Unfortunately Lasotas coyote tuning stuff stops before Gen 3 stuff which is basically godzilla stuff.
If you need tuning help id check out www.efidynotuning.com. The sites owner is named decipha and youll find him on many other forums by that name. The guy can make any computer run anything. He can add code to make pcms do things they were never meant to do. Your truck swap would be nothing for him.
The guy i finally found to tune it called it a Frankinstine .. its a 99 Navigator motor with a 2014 F150 6R80 in it . It runs thru a 2014 Gt 500 Ford Raceing control pack . I got it up & going drove it for awhile and something happened about the time my 67 vert fell in my lap . All i've did since then is buy a set of MMR adapters to put a coyote 5.o intake & throtle body on it . Bought all that stuff & some other parts i need to hopefully get it back online.
And ya that drive by wire is real different . I could see one of those Godzilla's sitting in my 59 T Bird
