I think I killed my engine - 392W
GrabberOrange69
Troglodyte
I built the 392W engine for my 69 Shelby in 2004ish. Its been through some abuse over the years and has seen 3 different intake/head configurations. One time I missed 3rd on a power shift and hit 7,000rpm and bent an exhaust valve (~2007). Last year I put a set of ported 351W heads on it, removed the headers and went back to stock look for the SAAC 50 show. That raised my compression from ~11.25 to ~12:1. I have run octane boost in all of its configurations, and for the last 7 years, its been fed a diet of 91 ethanol free, base fuel +boost.
Cylinders 1 and 6 have been oiling the plugs for some time, but it got way worse after the head swap. Its now a constant smoker (not cool).The Duraspark keeps firing through most of the oil storm, and there's no knock or bang or clack...but I'm taking it down this winter. I'll be aiming for 10:1 compression this time :) Its not a date code correct block anyway, so I think Ill hit up Don Rush at WCCC for a date code correct M code to start my next build.
Not a chemical engineer or anything but 91 seems pretty light to be running 12:1. When you say adding octane boost you aren't meaning the stuff like those old cans of 104 or whatever, are you? The science on those I've seen shows they don't do much of anything to raise the octane level of pump gas. FWIW, I run nothing but 93 in my 10.7:1 stroker.
That car says "Look at me!" and you'd better because it likely won't be still for long!
I'm sure you'll find a recipe you like.
I do agree the 92-93 or using track gas may be better for keeping it in one piece for now but 10:1 seems happy with the 90 to 92 non-ethanol around here.
I’m not a biologist either, but here I am having run it for 20+ years at 11.25 plus. Those CRs are static, not dynamic. This is what I run today https://www.summitracing.com/parts/btn-bstoct32pro1, but I don’t claim it’s magic. When I’ve cranked it up at the track, I’ve used race gas. Consistent 105 mph, but I’ve never had enough tire to hook. I’ve had the heads off twice since the original build, and haven’t noted anything that would make me change course back then. Back the timing off and you can putt the car around town on 91. Just have the self control to not lean on it.
I’m not building it the same way this time, too much hassle between timing and fuel.
