Fordman302
I just joined and I am currently rebuilding my 67 Mustang Coupe. Looking forward to being part of this site!
Had to chuckle at that one. Those B&M shifters haven't changed in 40 years. Had a StarGate in my first coupe back in the Eighties.Are you sure that shifter is big enough?![]()
Mine has a T5. It is a ball.Haha it was installed when I got it. I'm not a fan of it. I'm going to do a T5 swap here soon. I already have all the parts for it.
I'm running the stock 3:00 gears in an 8". I'll replace them eventually to something lower and trakloc.That's not to bad. I have an 8in rear end so I will have to go with 3.80 when I switch gears. I was also researching it and I guess the foxbody 8.8 is the same width as a 67 8in and 9in. So with brake line modifications and adding leaf spring perches you can install it in a classic mustang. Just not sure if it's worth the hassle lol. Foxbodys are 4 lug so I would have swap out axles as well.
The 8" is just fine for the street unless you start running crazy power.
Sent from my Pixel 2 using Tapatalk
The 8" is plenty for 300 hp. Way easier to just swap out internals.I was thinking of doing the same. 3:80s with trakloc.
That's why I'm not sure the 8.8 would be worth the hassle. I do plan on rebuilding the motor later on. But I only want around 300hp. It's enough to have fun but still nice to drive around town.
