well, I haven't made one in quite and I haven't done a Cougar but I imagine they are not much different. Nice Cougar by the way!Hey Tarafied1 are you still doing this mod? Have you done one for a 69 Cougar?
Well then I think I might be good because that filler neck insert looks to be about 1-1/4" deep so the 7/8" hole and flapper will be that far from the end. I ordered the parts last night including a replacement filler neck from WCCC so I will see what i'm dealing with once all arrives.there is a vent hole in the filler nozzle, it senses when the pressure increases and that's how the auto shut-off works. When the pressure increases rapidly it kicks off. That hole needs to be past the flapper to work correctly. I set my "plate" about an inch past the flange of the filler neck.
coolWell then I think I might be good because that filler neck insert looks to be about 1-1/4" deep so the 7/8" hole and flapper will be that far from the end. I ordered the parts last night including a replacement filler neck from WCCC so I will see what i'm dealing with once all arrives.
