3175375
on that pump, if you loosen the retaining nut on the back, you should be able to rotate the housing if you need to.
I actually cancelled my order and ordered the second one coz its the same dimensions as my existing one.on that pump, if you loosen the retaining nut on the back, you should be able to rotate the housing if you need to.
I did check them out, they are very expensiveTry National Parts Depot.
