Today and the last two weekends I have been getting started with installing the wiring harnesses. The kit came with new switches and I had already re-installed the OEM's (i,e, key, lights, hi-beam etc) so I replaced all of them instead of hoping the 50+ y.o. switches would not overheat and catch my car on fire. Had to re-locate the ignition control box 2 inches higher than previous because the sensor for the A/C liquid line clashed. More holes drilled :-\ I started threading the rear body harness through the hidden portions of the quarter panel thinking I could do that without removing a few of the interior pieces, After some struggling I determined that it would be faster to pull the rear seat back and the trim panel (not an easy task). Still need to connect the wire ends to the lights etc in the trunk. Today I spliced extra length to the ignition control box power leads to reach the solenoid and shortened the coil leads from the control box. First thing today I did a practice solder splice and shrink wrap as well as a practice wire end connection. Im satisfied that my soldering skills are suffcient and Im sure I will be expert after a few more hours of installing all the wires. Lastly, I attached a pair of wire clamps to the OEM location for securing the OEM A/C line. These clamps hold the new clutch cable and new A/C liquid line firmly without being overtight.
