Craig recently updated his ride with electric steering assist. There is a thread about it somewhere around here.You have power steering? If so do you ever have a problem with the rack and pinion hitting the ground?
I absolutely LOVE this car......hopefully you can get all the adjustment you need with the strut rod and LCA cam. I'm guessing that at some point whoever did the alignment didn't know this and not that something is bent.
I have the roller perches, the Arning drop and the eccentric eliminators as well as a roller idler arm and springs all from ORP and I used the ORP alignment specs too. I had a local Firestone shop do the alignment. They let me be in the shop and "supervise" or watch. I also got the print out. I told the shop manager what I needed/wanted up front and he was willing to work with me. I did later cut half a coil off the springs to lower it a bit more.
thank you sir, you working on yours still?I absolutely LOVE this car......
I still have a pair of red Kimi's to put in the tail of my Stang
I'm going to guess it's "Koni's" ...Kimi's??
Trying to. Making it out to Indiana often is difficult. Hoping to go before the end of the year again and get the front end structure welded up.thank you sir, you working on yours still?
Yeah, I covered that. Alignment is set when the car is stationary and the set-up takes into consideration how camber will change during suspension operation. The question was about would alignment need adjustment (correction) after the newly installed suspension had "settled" and the discussion was in regard to the fact that the only "settling" that happens relates to the coil spring which WILL NOT affect alignment.
To be clear, "ride height" does NOT affect camber either. Cutting a coil spring to lower the body and close the gap between fender and wheel doesn't change anything in regards to suspension alignment (unless this somehow changes the spring rate). If you change position of a control arm from the stock location (like the Arning drop) that WILL change things as you suggest but that was also covered many pages back.
Koni'sKimi's??
You should be able to just bounce it around it a little in garage without driving it. At least that's all I do. Seems to work fine.
I'll try that, when I dial it in.
Question: every time when I adjust the caster do I have to turn it back outwards and zero it out?
For the Mustang, it should just bolt in. You have to be cognizant of the trailing rods or whatever they are called, but it should be a no-brained. Ask me how I know
This. I'd bet on side or the other has been bent inward just enough to give you problems. Don't start grinding on the new parts!Obviously the brace that would t slides into must distorted slightly, I guess I just need to try and muscle it in.
