Since the accident, I have the following issues.
No headlights, no Gas gauge, No horn ( I think there was one more issue but cannot remember right now)
Since I was hit had in the front, I thought I pull the front harness and check for shorts of other issues. What I found was a bunch of splices and bad wires.
I am also moving the starter relay to the inside passenger kick panel
Got it out with minimal cussing.
First set of splices I found.
I installed a 1 wire alternator so I will also remove the voltage regulator wiring.
the is the connector that went to the stock alternator. What is the middle black wire to? The 2 on the top are grounds.
