As long as the engine is apart I thought I would dig a little more into my carb issue. I have a 18 year old Holley 770 Street Avenger vacuum secondary. After my disappointing low 13 second passes at the track I have verified the secondary's won't open. I used the paper clip on the linkage and it didn't move. I bought a new diaphragm but when I pulled the housing off before splitting it open, I checked it with my vacuum pump/gauge and it works. So I replaced the little gasket between the housing. Blew some carb cleaner back thru the hole and verified the passages are open. I put it all back together and it still didn't work.
Since I can't road test for a while and it's off anyway, I tried blowing air thru the venturi above the small port. Stiil didn't work. I replaced the diaphragm with the new one anyway, still didn't work. I took the no color "out of the box" spring out and put a yellow spring in (lightest). Still didn't work. Took the spring out completely and it moved but didn't open. I have an old 750 on the shelf so I checked it the same way. It worked. I swapped the housings between them and the 750 will work with both but the 770 will not work with either.
Any ideas what's wrong with the 770?
