I assume you have to change the computer for the engine swap? Keep posting your progress.
To continue what my dad said, the onboard security in the car unfortunately requires that I use my original computer. According to some other forum posts I read, the PATS system requires a matching cluster, key, and computer in order to inject fuel and fire the engine, so the GT computer stays. I will have to modify the harness but it will otherwise have no extraordinary issues running the 4cam engine. All the sensors are the same!
SO!
We had previously thought that my original engine had broken a piston skirt or two. After getting the engine to my friends house, who is rebuilding it for his car, we decided to tear into it a little. First, we pulled the oil pan. Everything looked mint, no metal shavings, no plastic broken stuff, nothing. Weird! So we flipped the motor back up and popped a valve cover off. It looked fantastic too, but there was a tiny bit of slop on the passenger side timing chain. Nothing to be worried about though, it definitely wasn't the problem.
We turned the motor back upside-down and started shaking the connecting rods. No slop. So we took the rod caps off of the two pistons that I suspected my noise was coming from. Bam! There it was, I had spun a rod bearing. I suppose I am fortunate that it hasn't seized up and come apart yet!
I decided to mock up all of my parts so far and have a few pictures. The cylinder head that needs to find its way to a machine shop leaks water so it definitely needs to be looked at, but this thing looks pretty great all mocked up. Once that head comes back, the motor will be 100% present and ready to be bolted together. 104 days until the twenty five hundred (2,500!) mile road trip!
