JRANGER
Yeah, i ordered a  National 7692S...Which has the extended rubber. Hopefully it will fit the 3 speed properly
I agree with gravity bleeding. I have a few different vacuum bleeders and sometimes they are good to get the fluid moving but quickly ditch them once there is fluid at the bleeder.The master should give a little squirt as the pedal is starting to be depressed. It lets the pressurized fluid back out of the calipers/wheel cylinders when you take your foot off.
Slow strokes tend to work better than stabs at the pedal, I find. I like to open the bleeders on the rear (calipers in your case) and let gravity feed fluid through the lines. Closing the bleeders and pumping the brakes and then opening them again sometimes makes this happen faster. Also gives you time to drink a beer while maintaining the fluid level in the master.
When fluid starts leaking out of one rear caliper, close it and wait for it to come out the other. Repeat this procedure for the fronts. *Most of the air will be out of the system at this point and it will be time for an assistant to pump the brakes while you Crack the bleeder.
I have used vaculas and mityvacs and all sorts of goofy bleeding tools. This is the procedure I have found to work time and time again on just about every hydraulic brake system, vw beetles exempt.
