I've replaced a number of parts during the re-restoration. All are for sale, most are heavy. I can ship, but it might be cheaper to pick up. I do have limited time during chemo treatments to send stuff out!
Powermaster XS mini starter. Guaranteed to fit a Toploader and 157 tooth flywheel. Part # 9503.3 (bought back in 2002 and worked great last time out.
Centerforce SFI rated aluminum 157 tooth flywheel, 28oz. Fits 289/302 crank...NOT a 5.0 crank. Never chattered, only 2 drag launches!
Tri-Y headers (can't remember the make), ceramic coated. Fit 289 heads (maybe 302 as well, not sure). Had to add one dent to clear the hi-po equalizer bar.
2+2 rear fold down seat carpet parts.
Lakewood SFI rated scattershield. Fits 289 6 bolt and 302 blocks. It does have the spring pivot for the bar. Bar and spring NIC.
A box of suspension parts. Used up, need to be re-done. Upper/lower arms, stock crossmember, front Koni adj. shocks, tie rods.
