Ok. Finally have a some pics and the time to post 'em up. A lot of time has been spent on it lately (as compared to the past at least). Not as much done as I would like at this point but there is a reason for that. Been doing a lot of mocking up and taking back apart. I tend to be fairly particular shall I say when it comes to my car. I have a vision of how I want things but it tends to change or evolve a bit too. Plus I find I stand around just looking at it daydreaming of what I want to do next.
When Mark was here we worked fairly quickly to try and get a lot done. There were/are a few things I needed to go back and finalize. One was the trans mount as I didn't have the right mount on hand at the time. Got that in and installed. I used a set of Ron Morris knock-off engine mounts which made it very easy to locate the engine/trans in the car. Check out that shifter location! No trimming of the hole. At all.
I got a lot of new stuff in the past week or so. Finally decided to just go with the MDL clutch hydraulic clutch kit. I really wanted to make my own but realized with my schedule it would never happen! I am changing it up a bit in that I will be using a different MC as I do not care for his low-buck remote reservoir set-up. I had a MC I bought and polished up a few years ago that is just about the same size that will work and look so much better.
Finally got to install my Lokar pedal and throttle cable set-up. Once I get the steering column installed onto the Borgeson shaft I can bolt up my wheel and pretend to drive!
Got all the stuff (I think) I will need for the brake lines. Going to use stainless and polish the lines. Yeah, I know. I just need to fab up a line straightener for when I need to make some longer runs. Do that maybe this weekend.
All my engine bay fuel line stuff showed up today. Going to go with all stainless braided and AN fittings. Lots of hoses to make up this weekend too.
Best of all the CVF Racing pulley set up came yesterday. Only problem is they left a belt out of the box. Should be here Friday. So glad I went this way. I wanted a sharp looking set-up but was not going to spend $2k on it. Simply couldn't justify it in mind. The pics of the CVF stuff do not do it justice. The machine work is incredible and the finish is gorgeous. Enough "bling" for my taste but not over the top. I think it really looks good on my orange Chevy engine
Anyway...some pics.
Anyway...some pics.
) makes a snide comment, yes I am doing something about the shock tower caps. I don't have the ones I want yet so using these temporarily.
