Nice! Heck of a deal.Nothing , but I bought this for $500 ....
That is so cool. Keep enjoying it and rack 'n 'em up!.......and I did after putting on another 78 miles
I strongly recommend you install (if not already present) a trans temp gauge. Most "trans coolers" are meant to work in conjunction with the set-up in stock radiators. If you missed it you need to check out Tarafied's thread about his trans failure. You may have inadvertently put your trans health in serious jeopardy.After the scary temps the 416 FE was running in Las Vegas. I decided on upgrading the 67's cooling system with a CR Racing aluminum cross-flow radiator from Precision Machines, which arrived today. I started off the day while waiting for the the man in brown to show by removing the old radiator and mounts and brackets then adding an automatic Trans cooler, as the CR cross-flow radiator is without. Finished the day dry fitting the new radiator and modifying brackets and the lower hose (from the water pump) for use with the supplied cross tube as both inlet and outlet are on the same side (passenger). Hope to finish up tomorrow.
Yeah but it is tainted by karma of the current owner.
Oh har, har, har. Bad karma, yes. Murphy's law, no. The only fantasy I have with my car is I might get it done.Don't worry, you need a RUNNING car to do damage to it. Fantasy cars are excluded from the bad karma. Just axe Jamie!
The filler opening and tank are on the driver side running top to bottom rather than across the top like the stock style radiator. That maybe why the inlet and outlet are on the same side (passenger).James67, are you saying that the inlet and outlet snouts on the rad are on the same side? Living under a rock, I thought cross flow rad's had the inlet snout on one side and outlet snout on the opposite side. Just got off of C&R's site. Lots of nice radiators.
I found that out with the first cooler I purchased stated in the instructions that the cooler had to be used in conjunction with the one in the radiator. I returned that one and purchased another that was three times the size of the previous one which the people at Hayden said would do the job. I'm also running an extra capacity finned aluminum trans pan which should help.I strongly recommend you install (if not already present) a trans temp gauge. Most "trans coolers" are meant to work in conjunction with the set-up in stock radiators. If you missed it you need to check out Tarafied's thread about his trans failure. You may have inadvertently put your trans health in serious jeopardy.
Sounds like you have it covered. Didn't want to read about another Fixer cooking their trans.I found that out with the first cooler I purchased stated in the instructions that the cooler had to be used in conjunction with the one in the radiator. I returned that one and purchased another that was three times the size of the previous one which the people at Hayden said would do the job. I'm also running an extra capacity finned aluminum trans pan which should help.
Got everything moved back in the shop and pulled the motor....again.
Also attached a pic just for Mark.
