Problem with rear drum brakes, I'm out of ideas.
Discussion in 'Engine and Drivetrain/Mechanical' started by msell66, Jul 19, 2018.
  1. msell66
    msell66 Burning Fossil Fuels as Fast as Possible Donator
    So, I changed from the stock 10x1 3/4 drum brakes to 11x2 1/4 last year. New everything including the backing plate. Since installation, I've had this same problem.
    When I put the drum on the axle hub and then snug up the brake shoes so they just start to get drag, I can easily spin the axle with my hand. If I either tighten the drum down with lugnuts only of wheel and lugnuts, I can no longer turn the axle or tire by hand.
    Things I've checked:
    Axle flange runout checked out less than .003"
    Axle is square to the flange
    New axle bearings
    Drums have been turned
    Shoes sit fine depthwise into the drum. They are not touching the drum anywhere except the shoe face.
    The shoes are the correct radius and fit the drums perfect.
    I've used white chalk everywhere to see if there is rubbing. No witness marks other than the shoe face.
    If I adjust the shoes in at the bottom so that when tightened down it does not affect turning by hand, the brakes don't do squat when the brake pedal is pressed. If I do adjust the shoes so they have the correct drag and then tighten them, I get major brake fade pretty quickly on track and the drums get super hot.
    I have yet to check if the backing plate is square with the axle flange. That is the last thing I can think of to test. I've discussed this with John at ORP and he said no one else has had this problem with this larger brake kit.
    I realize that due to the drugs I've had over the last 3 years, I'm limited in my ability to diagnose problems. So now, it's up to yoose guys!
    [​IMG]
  2. tarafied1
    tarafied1 Well-Known Member
    It is the same on both sides? The problem I mean.
  3. B67FSTB
    Maybe your drums are oval ? Put them on a lathe and see if they are round .
  4. msell66
    Yes
    Mark
  5. msell66
    Drums have been turned/trued.
    Mark
  6. B67FSTB
    Drums are turned I see.
    Are all 4 brakeshoes the same ?
    Sometimes the front faced brakeshoes ( the rightone on the right side and the left one on the left side ) are the one with the lesser friction plate.
    comprende ?
  7. msell66
    Porterfield R4 shoes. All the same. No front or back.
    Mark
  8. B67FSTB
    Axles itselfs ?
  9. Midlife
    Brakes on the wrong side?
  10. steveh326
    steveh326 Active Member
    only thing I could think to try is maybe some blue tape on all potential sources of the interference, reinstall the wheel then remove and see if there are any indication on the tape of where it is happening?
    msell66 likes this.
  11. tarafied1
    Is it only when lugs are torqued? If they are just finger tight dies it do the same?
  12. David67
    David67 Active Member
    Buy a new drum and put it on to see if it still drags. Maybe it's the design of the drum?
    Sent from my Pixel XL using Tapatalk
  13. msell66
    Checked by local performance shop. Ok
    Mark
  14. msell66
    Even tightened by hand with three nuts locks it down.
    Mark
  15. msell66
    Tried that. Same result.
    Mark
  16. msell66
    No
    Mark
  17. tarafied1
    do you have pics of the inside and outside of the drum(s)?
  18. kb3
    kb3 Well-Known Member
    Without re-reading everything, are the drums dragging on the backing plate?
  19. tarafied1
    couple more questions:
    Do you have a parking brake?
    If so can you cause the wheel to lock up with parking brake set, when shoes/adjuster is set to spin freely while lugs are tight?
    Do you have an adjustable proportioning valve?
    can you set the shoes/adjuster to spin freely and adjust the proportioning valve to give more rear pressure? And by doing so, then cause wheel to lock up when brakes are applied but still spin free when not applied?
  20. msell66
    No
    Mark
