"tarafied1" said:Let me know if it's a problem for you.
No problem Craig, thanks again! I did not think that it was that big of a deal. I installed it this afternoon.
"tarafied1" said:oh bummer! That is a deflector that is supposed to be behind the drain hole so gas can't splash back thru the 1/8 inch hole. I'm glad it didn't fall off before you installed it. I usually check those with the pliers to make sure it's solid. Let me know if it's a problem for you.
I will be doing tighter quality control on those for sure!
Thanks for letting me know about it. I'm sorry.
"Indycanard" said:After a few warm days, I started to notice a gas smell in my car. I thought it was perhaps just fuel from the carb after shutdown. I checked all over for any signs of a fuel leak. None found. The last place to look was the modified fuel filler neck. I turned off my garage lights, and used a strong flash light. I stared down the fuel neck, while lighting up the fuel neck inside the trunk. I saw a small light leak into the filler. I found my leak. The welded in plate had a small burn thru was allowing fuel vapors to fill my trunk as the temperatures fluctuated. I put some tape over the area until I am able to get it fixed (rewelded?). I guess this is just a heads up. Fuel vapors can be a very bad thing. Unless the tank is full, the cooling/heating cycles can pump out significant fuel vapor volumes.
Henry
