sigtauenus
So I'm still shaking down the car. Had a tach issue, posted that in the electrical board.
Had the car outside the garage today idling to get the engine up to temperature, which it did normally after about 5 minutes or so. All indications normal, fuel, tach, temp all working fine.
I had the radiator out of the car to install the a/c condenser, and filled it back up with coolant and overfilled it. My car likes a lower than normal coolant level, so I just top it off, let it burp out via the overflow whatever it doesn't want (another reason I had the car in the driveway vice inside to warm up).
So the radiator started pushing out the extra coolant, which is normal, but then the temp gauge went up to high. That is very weird, I've never had an issue with overheating with this thing. I went around to the radiator and the radiator was cool to the touch. It didn't make sense to me that the temp gauge would be showing hot but the radiator would be cool.
Combined with the tach issue, I'm not sure if I have an electrical/sender issue or an actual overheating issue. Water pump and thermostat are new, well, they are 2-3 years old now, but have less than 100 miles on them.
Suggestions?
Suggestions?
