Was someone looking for a VW van....
AzPete
Just a short ride from central Cali.....
http://panamacity.craigslist.org/cto/5044225559.html
1970 VW Bus Kombi Westfalia - $10500 (Jax Beach)
2014:
Master Cylinder, line from reservoir to Master cylinder, brake light switch, all wheel cylinders, all flex lines, hard lines on outer sections, all brake shoes, springs and stars. Tranny nose mount, mustache bar mounts, throttle cable, clutch cable, automatic starter, axles end to end, 15" bus wheels, new 215x75x15 tires, hitch carrier, interior panels, interior floor, seat covers, seat covering, curtains, fog lights, upper off road lights, swing away jerry can holder, stereo, coil over shocks, cb PA system, wiring for all lights, clutch, pressure plate, throw out bearing, engine rebuild 10/15/2014-1776, 90.5. Big valve heads with 3 angle cut and rebuilt head. All valves and seals new. C25 cam,Weber progressive carb,single vacuum advance dist, 55 amp at all gaskets and tubes. tent is in good shape with screens and zippers. Windshield has a Crack but does not leak. Steering is a bit sloppy but is manageable. I drive it daily.Clear Florida title. Thank you for looking. VEHICLE IS FROM CALIFORNIA WITH A CALIFORNIA VIN PLATE BUT IS CURRENTLY IN FLORIDA.
