Okay, I went with all your suggestions on my squealing/grinding noise. I looked between the motor and block plate and saw my pinion of the starter. It looked like it was still slightly meshed with the flywheel. Pulled the starter. Sure enough the end of the pinion was wasted. Took the starter back to napa. They pulled another from the back, and it had a shorter snout then the one I had. Turns out I had the wrong starter. Put the new starter in, and other then a gas leak on the return side she fired right up... NO NOISE. I only ran it for about 20 seconds due to the gas leak. Will fix that tomorrow and post a video of it running..... 11 years in the making and finally it makes noise on its own... other then me sitting in the drivers seat making car noises.
Things are beginning to look up.
