66gt350
I'm thinking of re-camming my fastback.  I'm not that happy with the Ford Motorsport E303 cam.  Trying to get the efi tuned is becoming very frustrating.  Ok here's a quick rundown of my setup:
engine out of a '89GT
bored .030 over
flattop pistons
Twisted Wedge heads
IIRC, I'm running about 9.5:1 compression
Holley Sytemmax II intake
Accufab 70mm throttle body
24 lb. injectors with pro-flow mass air meter. (I do have 30 lb injectors, if needed)
tko 5-speed
3:50 rear end
As I stated, I'm currently running the E303 cam. Here's the specs:
E303
duration 282 Intake & Exhaust
duration 220 @ 0.050 Intake & Exhaust
lift .498/.498 Intake & Exhaust
110 centerline
I've called Clay Smith Cams and Comp Cams for they're recommendation. Here's what they recommended:
Clay Smith
HR280-12-CFR - part number
duration 280 Intake & Exhaust
duration 230 @ 0.050 Intake & Exhaust
lift .512/.512 Intake & Exhaust
112 centerline
COMP Cams Xtreme Energy Camshafts
35-349-8 - part number
duration 264 Intake
duration 270 Exhaust
duration 212 @ 0.050 Intake
duration 218 @ 0.050 Exhaust
114 centerline
This is my daily driver, so I'm not looking for more power. I can already light the tires up easy. I'm looking for a nice cam that will cruise nicely to get me back and forth to work...but still have a little fun with the ricers when needed!!
Any opinion?
thanks
bored .030 over
flattop pistons
Twisted Wedge heads
tko 5-speed
3:50 rear end
E303
110 centerline
Clay Smith
112 centerline
duration 264 Intake
114 centerline
Any opinion?
thanks
