PM 65
living overseas
Hello Mustangers,
i have a 65 Mustang coupe which has a very low handbrake power since i have the car. To be clear about it, if i pull the handbrake completely, the car still rolls when i push it very hard.
So i went underneath the car and checked the handbrake system, looks very good. According to my manual the lever system near the gear box is installed correctly.
My car is equipped with a Lincoln Versailles 9inch rear end with the original disc brakes and calipers on it.
The handbrake levers at the rear calipers are working at a big angle when i pull the handbrake! Whooops? Please see attached pictures at the end.
After checking dr. google this shouldnt be. My suggestion is that the last owner of the car changed the brake pads and didnt rotate the brake caliper pistons when pushing it back.
Could this be the reason for my low handbrake power and / or the big angle of the caliper handbrake lever?
Would it help when i dismantle the brake and rotate (clockwise?) the caliper piston? I have the tool for it.
Could the handbrake system in the caliper be damaged if the piston was pushed back and not rotated?
Any info and your help is very appreciated, thank you!
Mario
Mario
