"Midlife" said:Wow! That second picture is not good!
Another possibility for fuel in the oil is a bad diaphragm in the fuel pump. That's a cheap fix!
Midlife, I was thinking also about changing fuel pumps. This one is new but you never know. I also put a pressure gauge on the fuel line and it shows right at 6 pounds.
"Ricks 70 stang" said:I believe that I will cut my loses with this demon and go on from there. I bought a new fuel pump and will try it also. Does any body have an opinion on the summit carbs?
Thanks
