Need part locate help
Mach1Mark
Ramrod extraordinaire
Ive been restoring the seals on my wind wings and need to locate the rubber bedding between the wind wing glass and the 2/3's frame (see pic). I need this seal ASAP. Thanks for your reply.
Still not sure which item you are referring to. Can you highlight the correct item in the pic?
Glass setting tape is what is used between the glass and the stainless frame. 1/16" thick tape is the thickness I used. If you have a local glass shop, you might be able to get some from them (just don't get it with the cork/rubber styles).
I got mine from the following ebay seller.
http://cgi.ebay.com/ebaymotors/Glas...tZVintageQ5fCarQ5fTruckQ5fPartsQ5fAccessories
When you install it, soak it in soapy water, fold it lengthwise, then partially set it into the channel, then with a wooden mallet, tap the frame onto the glass starting at the corner working your way out to the ends (back and forth a little at a time until it seats... then use a razor blade to trim the excess... Pretty easy to do.
FYI... if you ever need to the bottom of the door glass to the regulator frame, that uses 5/64" tape.
Craig
I am looking for the rubber bedding (seal?) between the glass and the frame. stangg gave me a direction, Thanks for the assist, stangg !!
Ordered some rubber bedding yesterday from seller on ebay. Thanks for the assist !!
