Need a suggestion to fix my shifter
I need some suggestions.. There are three bolts that hold my sifter to the transmission. The front bolt that I circled in red has a sheared off bolt in in. I pulled the transmission and tried to drill it out with a colbat drill bit and the bolt is so hard, I could not drill into it after about 3 hours.. I screwed up the threads and jb welded a heli coil in it. The back two bolts keep working their way out even after locktight. shifting the car works it out in about 2 - 3 months. I have wrenched it down as tight as I could get it.. I REALLY don't wnat to pull that transmission again.. Any thoughts?
Uhhhh....lock washer?
If you go the safety wire route harbor freight has safety wire pliers. Heck you can borrow mine.
