"gotstang" said:NBs are dang near useless for tuning...they are good for mixture correction on EFI, but they don't give you enough data in terms of real #s to be useful when tuning a carb or doing a dyno tune on an EFI car.
You can build your own wideband for cheap too, I can't think of the guy's name that makes the kit, but it's way less than $150 and uses a stock VW Wideband 02, which is neat, not too many cars use widebands from the factory. A wideband gives you your A/F ratio, whereas a NB just reports rich or lean.
"apollard" said:You can find Innovate Motorsports widebands on the net/ebay for ~150. Works great and has datalogging capability, but you'll need a laptop (even w/o doing the logging)
"gotstang" said:the cheap Innovate LC1 doesn't do datalogging, and if the sensor dies, it's a fortune...unlike the JAW.
"garner67" said:Question: When installing the O2 sensor into a dual exhaust system, where do you install the sensor?
Does it make a difference if the O2 sensor is installed on only one side of the exhaust system, which means you only read one side of the engine cylinders?
Or should the O2 sensor be installed in the center of the H-pipe or X-pipe (if the exhaust is so equipped)?
"Fast68back" said:I have a JBA H pipe and it has 02 bungs built into it. The kit came with threaded plugs if your not running EFI
"daveSanborn" said:I welded in bungs on each exhaust pipe just aft/downstream of the header collector/exhaust pipe joint.
Spark plug "extenders", available at your local auto parts store work perfectly as O2 sensor bungs. Some minor trimming of the extenders is necessary, they weld right in and they're threaded to accept the O2 sensors.
