OK, so my 65 has had pretty much everything changed or refinished. I replaced the turn signal switch when I redid the interior this spring and now the car is done right....not so fast.
My horn makes a weak "Grunt" when I push the horn button, so I figured it was a bad ground on the horns so I clean off some paint and made sure the star washers had a good bite and double check and its not the problem. If I send a power jumper from the battery to one of the horns they both honk fine, so its not a ground.
OK, its gotta be my old original plug that the new column harness plugs into right? Well, if I short between the two corner wires (Yellow & Yellow/green) on the original plug (Car side) the horns honk fine.
When I check continuity on the column side plug when I push the horn button it shows contact closure.
I was really scratching my head here so I plugged everything back together under the dash and pulled the wheel back off (Lecarra) and put a jumper across the two spring posts and all I got was a "Grunt" (With some heat). The terminals are new, they look fine and the springs allow them to slide... but I cannot get them to act right? Its like they are not allowing enough current through. I cleaned em with lacquer thinner and then a scotch-bright with no change.
What is going on? I am going to try and remove the turn signal switch and flip it over tomorrow and see what gives, but I am really curious as to what would cause this to act this way?
