toddwallace
I have a 1966 "T" code mustang that has has a 2bbl Webber DG98 and manual choke with the Clifford 2bbl adapter, Pertronix, Classic Inline Dual Headers..
Car sat from 2006 in a garage and had not been started... I replaced radiator, water pump, thermostat, belts, hoses, plugs.. Drained all the fluids and replaced.. had the carb rebuilt...
right now, the car needs exhaust and is just open headers. Muffler shop wants it idling so they can check for leaks..
car is very hard to start. When it does hit, it idles up and dies. Seems to like half choke after it does warm up to attempt to idle. I had a mechanic check timing and vacuum leaks. He said that I need to drive it for awhile, but don't buy that. I'm hoping the motor is good, but it does not smoke. I just can't get it where it is easy to start and/or idle. After the motor gets warm, you can wrap on the accelator and the car revs fine. ultimately, the car will idle ok when it gets warm/hot. When it is like this, the car does not seem to have any power or torque. It dies trying to get in on the trailer and requires 2 people pushing it from behind.
What are you thoughts? Anyone in the DFW area that can help??
