Meyer65
So on my drive home from Hot August I noticed the friction point on my clutch was WAY low, like almost to the floor. I managed to make it home in one piece, and when I popped the hood I noticed the fluid in the remote reservoir was low (I am running a JMC system with an external slave cylinder)
So I added fluid which did nothing (which I figured, but it was worth a try!)
So then I decide the system needs to be re-bled (a nightmare, as many of you know)
So anyway after a lot of failed attempts I remove the slave cylinder so I can properly bleed the system.
Only here's the thing, I have essentially drained all of the fluid between the master and the slave, but the fluid level in the reservoir has not gone down even a little.
So does this indicate that the Master Cylinder is in need of a rebuild, or what? I'm not sure what to do from here...
