Hurst Shifter
I know I've seen T-handles with the button on hurst shifters but I don't know if the handles were from hurst or not.
I've also seen a ball shifter with an integrated button. The line lock button used to be attached just below the shifter ball but was a separate unit from the handle.
I have a T-Handle Hurst shifter with a line lock button. The handle was hacked up in years past though and the wires for the button were pulled out or cut so I can no longer use it. Check the Hurst website, they have a catalog and you should be able to order one through them that will work (or they can tell you where to go to get one at least).
Edit: Here is what I have: http://www.hurst-shifters.com/hurst-products/Knobs-and-Handles/Polished_t_handle_with_button
