Fordrevhead
New Member
Almost every single mechanical part has been replaced or rebuilt between 1993 and 2010. I have a shoebox full of receipts.
Completely Rebuilt 1979 drive train, approx 15k miles on rebuilt engine and transmission.
Engine:
Completely Rebuilt 1979 302
Bored .030" over
Forged aluminum TRW flat top pistons
Crane Fireball cam & lifters
1979 steel heads rebuilt and port matched to headers
Edelbrock Performer Intake (Port matched)
Holley 600 with 1" spacer.
MSD billet distributor
MSD 6AL box with rev limiter chips
Taylor plug wires and loom brackets
Reverse Water Pump setup with full GT single serpentine belt setup and auto tensioner
March Underdrive pulleys
Rebuilt Starter
Rebuilt Alternator
Low mileage Power steering pump swap
New battery
New triple core radiator
Holley red electric fuel pump
Transmission:
Completely and meticulously rebuilt 1979 C4 Auto
B&M street/shift kit modified valve body
B&M stall convertor
Hays Flex Plate
Hurst ProMatic 2 ratchet shifter
B&M Transmission Cooler
Rear Differential
Traction Lok rear differential with 3.73's
Complete new locker center section (cage, spiders, clutches and discs), all new axle bearings, axle shaft seals, fluid, friction modifier (2010)
Tranni fluid and filter change (2010)
Exhaust
Blackjack Longtube Headers
Hooker 2.5" H pipe,
2.5" Hooker aluminized dual intermediates,
Hooker lifetime warranty Super Comp mufflers,
2.5" Hooker aluminized tailpipes
Wheels and Tires:
Front 15x7's Centerline Star Billet Aluminum Wheels with BFG Radial T/A P225/60R15's
Rear 15x8 Centerline Star Billet Aluminum Wheels with BFG Radial TA P245/60R15's
Full size spare in trunk on matching 15x7 Centerline Star Billet Aluminum Wheel
A second spare 15x7 Centerline Star Billet Aluminum Wheel
Suspension and steering:
Rebuilt R&P
Replaced rag joint
1-1/8" front sway bar with poly bushings
7/8" rear sway bar with poly bushings
FMS high rate springs
Lakewood 60/40 rear drag shocks
Southside machine lift bars
Chassis:
Fully welded torque boxes
Subframe Connectors, Welded with seat and floor supports
Chrome strut tower brace
K Frame Brace
Body:
2" Fiberglass Cowl Induction Hood with hydraulic lift cylinders
1969 Ford Royal Maroon acrylic enamel, painted in 1993.
Window Tint
Lund Rear Window Slats
Larger epoxy treated gas tank
Interior:
AutoMeter Temp/Oil Pressure/Voltage gauges under center of dash
AutoGage Tachometer by AutoMeter on column
Black 79 Steering wheel
Black dash cover
Original Red has been vinyl died maroon
Custom Headliner
Pioneer Supertuner III am/fm/cd and antenna booster
I have a spare stock hood painted to match. I have a third stock hood in 2k sealer with a dent that's fixable. I have two or three spare driveshafts, Fox body oil pans, steering column covers, glove box covers, cowl covers, visors, glove box doors, window molding, etc. I have the original front buckets that could be redone. I have the original door panels, current ones are from an 81. . . probably more.
There is some blistering on the wheel openings and one small hole developing in the right rear lower. The body is otherwise very good and the car is very stiff and solid underneath. I have owned it since about 1990 and it has been garaged ever since and has never seen snow since then. I have too many projects and it is time for this one to move on to someone else who can enjoy it. It is very dependable and has never stranded me. Could certainly be daily driven again. I would like to see this go to a good home. Someone who does there own body and paint could certainly bring this to show worthy fairly inexpensively but really it has always been a driver for me.
Engine:
Bored .030" over
Rebuilt Starter
Rebuilt Alternator
New battery
Transmission:
B&M stall convertor
Hays Flex Plate
Rear Differential
Exhaust
Hooker 2.5" H pipe,
Wheels and Tires:
Rebuilt R&P
Replaced rag joint
Chassis:
K Frame Brace
Body:
Window Tint
Interior:
Black dash cover
Custom Headliner
