I have only had one FMX and it was in a car I bought for parts. I can't say they are not better but C4's have much more support in the aftermarket. They can be pretty tuff but need some modification for serious abuse."jmbour66" said:Any opinions on which is better: C4 (1973) or FMX?
The FMX was the standard transmission behind the 351W in 1969, and I believe it was used extensively in later Ford products behind the small blocks. The early 351Cs had a C6 behind them IIRC."Ponyman66" said:I honestly don't know if an FMX will bolt up behind a small block. IIRC it'll bolt to a big block or (at smallest), a 351C/M. It really was never considered to be a performance tranny. AOD's are another good choice, but just like a C4, they can be built to hold some pretty good HP, but need work to do so.
"RagTop" said:The FMX was the standard transmission behind the 351W in 1969, and I believe it was used extensively in later Ford products behind the small blocks. The early 351Cs had a C6 behind them IIRC.
If it were me, I'd go with the AOD before I beefed a C4. Three speed trannys limit the rear gearing you can practically run with on the highway. My convertible has a C4 with 3.55 gears and turns around 4K at 80 mph. My son has a SportsRoof with an FMX and 3.73 gears and it howls at highway speeds (the engine, not the gears). Nearly undriveable, and the gas mileage on both cars sucks.
Hi Jeff:"JeffTepper" said:Hey Ken:
How's life in Lincoln? Until two years ago, I had a dear cousin that lived there and I remember visiting her and JohnPro the same day, just a few months before John was diagnosed. Unfortunately, both of them are now gone. :shrug
Regards, Jeff
