DougG69
Anyone else have to slam the doors shut with new weatherstripping? Any advice on making it easier to close the doors?
"SAC69" said:My pass side operated the same but the drivers' was a significant problem after I replaced the weatherstrip. After checking it out, it seemed the problem was at the large, thick rubber section at the end, near the lower door hinge; it was too thick/wide. It was really jamming against the hinge pillar before the door was 2/3 closed. I used a razor blade to trim off approx 1/4" - 1/3" and the door closes much better w/o any air leaks either.
"DougG69" said:Hmm... there's an idea. Mine has the pretty much the same symptom - I can feel resistance when the door is 8"-10" from closing.
Did you trim from the inside (side glued to door), or the outside?
"SAC69" said:I trimmed the large rubber piece that sticks out and hits the hinge pillar. I can send an image if needed, just send me a PM.
