Its been awhile since I've been on here, so I thought I would update you on my latest workings on my mach. Recently there was a Cobra Automotive Crossmember DIY thread on the VMF, where a guy got ahold of the 65/66 crossmember dimensions and posted up the end bracket drawings. I tracked down the 67/70 crossmember and got the dimensions on the end brackets as well. So with that, I've decided to get my butt in gear and get mine fabricated since I've been putting it off for nearly 2 years! A little background.....I dropped my motor 1" and moved it to the rear 1.25", so the stock crossmember no longer fits nor will the stock CA crossmember. Rather than purchasing and hacking up a $200+ crossmember, I'm making my own. Below are a few drawings with two options. Both utilize 1.5" x 2.5" x 3/16" angle iron end brackets and 1.5" x 1/8" wall steel square tubing for the center tubes.
Option 1 is the stock CA type which requires you to cut a slot on the angle iron and bent the horizontal leg down, in which you weld to tube to. My tubes approach that bent leg at a larger angle than the stock CA crossmember due to my lower oil pan, and with only one side of this angle welded/braced I have a small concern about the outer face bending. A simple gusset would fix this.
The 2nd option, is simply removing the bent angle leg and extending the tube onto the vertical face of the angle. The hatching is the fillet weld. I drew in a 1/2" ID (1 1/16" OD) SAE washer with the bolt shoved as far as it would ever go, and I have 3/8" clearance from edge of washer to the edge of the tube (not including fillet weld). The tube has a radius at the corner, so the fillet weld will likely be minimal. I also won't need a continuous fillet weld, so I could probably stop where the washer would get close.
Option 1:
Option 2:
Closeup of End Bracket on Option 2
So, which do you think looks stonger and/or easier to fabricate? Looking for ideas of improvement or just general feedback! I know I'm approaching super overkill for a mostly street car, but when I do something I find any weakness (at least in my mind!) and make it better. Option 2 isn't as aesthetically pleasing, but this isn't a show car and few will ever see this crossmember. Eccentric eliminators will be utilized between the LCA mount and crossmember.
Option 1:
Option 2:
