CPP suspension, unisteer, 4r70w, and JBA headers this week
classicdoug
Hey all,
I've finally found this place. I wondered where all the good advice (and bs) went.
I've finally started working on my 65 fastback again this week. I've had all the bodywork done and complete car in primer for a few months now. I wanted to mock up the engine/suspension/steering before going any further. I installed the CPP mini subframe and suspension, Unisteer power rack and pinion, Ididit column, and a 289 (soon to be 347) with JBA headers and 4r70w to make sure everything worked together. I couldn't ask for a better fit. The only modifying I had to do to any of these things was to slightly enlarge the mount holes on the unisteer crossmember and slightly grind near the lower control arm bolts (probably took off no more than 1/8 inch). That probably took an extra 15 minutes, but everything else unisteer sent in the kit fit perfect, even the steering u joints and shafts that hooked to the ididit column. I bought the column from ididit which came with a floor mount and uses the original dash mount bracket. Even the JBA headers fit without coming close to touching anything. I made a tranny mount for the 4r70w and next up is welding in the Tin Man subframe connectors. All in all, it has been a good week.
Doug
Welcome aboard Doug.
I might as well tell you before someone else does.....
Around here, it there aren't pictures.... it technically didn't really happen.
Sounds like you've made a lot of progress (purportedly). When is the car scheduled for the paint booth?
That about sums it up... Its kinda the number one rule since we are a visual bunch. Except mark, word is he's blind. :gobp
Anyway, welcome to the Fix. Pull up a seat and stay a while! :craz
Please make sure to post the pics in braille......welcome a bored Doug!!
... .. ..... .. . ..... .... ..... ...... .............. .. ....... ....... ... ........ ... . ..... . . . .... ........ .... :ep
Translated.....Teach me how to pass the Pt Cruiser.........please....
sounds like what i have... 289 stroked 347, JBA Tri-Y headers w/ a ding from the pitman arm. maybe i need a R&P?? i need pix!
LMAO pete
You're going to love those Tinman subframe connectors. I think they're probably the best connectors on the market.
