Coolant for aluminum radiators
Most coolant today is Alum safe, But I would check the label to make sure.
Some of the older coolant types would have chemicals that corrode the Alum.
A lot of reading I found says the Zerex G-05 works good with both the aluminum radiator and the heater core if it is not aluminum. And as stated, most all are good but just read the jug before consuming.
I've never used anything special in any of the aluminum radiators I've run ... just a 50/50 mix of anti-freeze and water. I've never had a corrosion problem, at all.
+1. We use whatever conventional coolant is on sale and never a problem.
Why don't you Arizona and California guys just use water? Coolant is really anti-freeze, and I'm thinking you don't really need freeze protection do you? Anti-freeze actually lowers the boiling point of water.
Tim
"AzPete" said:
Coolant raises the boiling point.
:wstup
It raises the boiling point, and lowers the freezing point. It also adds vital lubricants and anti-corrosion stuff to keep water pumps from failing and radiators from corroding. Running straight water is a very bad idea.
You can use Water Wetter and water, but a bottle of Water Wetter is harder to find, and just about the same price or more as a gallon of anti-freeze. I have tried the Water Wetter in the past, and never notice one iota of difference in operating temperature.
I just put a new Northern aluminum radiator into the D-coder and am using 75/25 distilled water to propylene glycol and water wetter. Thing runs like an iceberg, right at t-stat rating. Can't imagine why I suffered through all those years of messing with cooling system stuff.
I did notice it took a couple good hard high speed trips into town to settle out the operating temp. Perhaps it was burping the air out. Now, even heat soaking coming off the freeway on a hot CenCal day doesn't get the OEM temp gauge to halfway, where before it would be way over to the first hot line.
Distilled water and 40 Below. Thats all I have ever used. Reno heat, no problems. Bay area weather, no problems. Cheap. Two gallons of distilled water from Walgreens $1.00 on sale! 40 Below is mail order. Don't remember the price. Autozone used to carry it. Maybe Vic Hubbards or Gotelli's Speed shop.
Nothing special in my aluminum radiator either, just plain ol 50/50 mix of water and the green antifreeze.
My daughter's truck has the red crap. Most of our buses have the red crap. All my cars have the green crap 50/50 with distilled water. Well maybe a bit stronger, I just eye ball it.
The 65 has an aluminum radiator and I run the 50/50 green crap.
I have been known to feed it to the local wild cats too.... But that is a whole different thread.
PS. Oh, yea, I like the antifreeze instead of water because the chemicals in it will inhibit the electrolysis between the different metals, I think. MH
