"bigb427" said:If you don't want to make a mess or damage any painted surfaces you can use propane in the same manner as spraying carb cleaner or brake clean. OTC makes a kit that is a little pricey, but you could probably rig something up that will work just the same. Here's a link to the OTC kit: http://www.amazon.com/OTC-7148-Propane-Enrichment-Kit/dp/B0002SR5N0
"bigb427" said:OTC makes a kit that is a little pricey, but you could probably rig something up that will work just the same.
