camber adjusting kit for 65
65-408
Advantages?
-better tire to fender clearance
-easier than UCA shims?
The only down side I see is that you are fixed to the total adjustment range and increment?
Anyone know what the adjustment increment is on these kits?
Thanks,
Jeff
I think they are great. You should be able to bolt the UCA to the tower, removing the shims and gaining a little tire to fender clearance.
I've found by just using the eccentric to set camber you can get either side within 1/4 degree which I find is acceptable. If you want to get more precise than that, shim the UCA.
