Dne'
Hi y'all! Guess it's about time for something to mess up! I finally got my stang home, it's been at moms while I work on the apache.
I bought an MSD ignition to replace the HEI, but just the basic setup. I installed it and it ran great for several miles, parked it for a few hous waiting for the muffler shop to get my new exhaust tips
:yah, but when I started it and backed out of the garage, it died suddenly!! :wtf
I called tech at MSD and they guided me through the process of checking the ignition system, after many phone calls and it still not even act like it would crank , I started checking EVERYTHING! LSS- I moved the distributor all the way towards the thermostat housing and it started
art! But when I tried putting it back to the correct timing, it would die!
I called Herb(of course) and he was discombobulated as I still am! The photo shows where the timing is at this time. The onLy other thing I can expose is when I spray carb cleaner around the right side of the intake manifold, the engine starts chugging suggesting maybe a vacuum leak? Herb's going to come over sometime soon to give me his much needed advice of how to proceed!
I had the wires all neat; now it's not organized looking, so don't worry, it will look nice and neat when this is all over.
Advice is absolutely welcome; )
Dne'
One other thought, when I went to install the new distributor, I had the option for different mechanical advance springs, tech told to use some light blue springs for street, just thought I'd mention that in case it had some drastic effect on the timing.
Pss, the photo of the timing was taking with the engine running.
Dne'
