Any info on this?
34isgreat
Anyone know what this is? I know what the warrenty card is but the black tag, What is this for? What do the numbers mean?
Top left c/o 352 what is this?
Second row,, 1 G13 then my vin number. What is the 1 and the G13???
Third line 65 A, V then 2F. I know what these mean.
It pretty much tells how the car was to be built going down the line. Most I have seen were on the left fender, held in place with a flat headed phillips screw. Google buck tag and you should find a few sites that give all the info.
http://www.kcode.net/bucktags.htm
Of course, don't quote me to much on this.....
When I first started working at our local Ford Assy Plant, we were making the mercury villager. I did some work in the body shop and paint dept. back then the buck tags were used in those two dept. for assy info. Once the body got painted and arrived at the trim dept. it received a rotation number and build sheet for the trim and chassis assy. process. As Paul Harvey use to say, "and that's the rest of the story, Good Day"
