I am a little confused about how to wire the yellow wire on the 3g alternator. After a lot of searching there seems to be two different thoughts or methods about where to connect the yellow voltage sensing wire.
A lot of sites say connect the yellow wire back to the battery connection on the alternator.
Others say connect it back to the starter solenoid.
I have relocated my battery to the trunk and I rewired the car with a Quick Wire 14 circuit harness, my 3g alternator is wired with 2 gauge wire to a distribution point by the fuse block then a 4 gauge wire back to the trunk to a 150 amp fuse.
Method 1:The method that connects the yellow wire back to the alternator’s positive post senses just the voltage output of the alternator, and adjusts output to run power and charge the battery. Some concerns are that with this full alternator output may overcharge the battery making the battery or regulator pre-maturely fail. I have seen anywhere from 125 to 200 amp fuses protecting the charge wire and some diagrams show a 20 amp fuse on the yellow wire.
Method 2: According to Mad Electric, the yellow wire needs to be connected at the distribution point so the regulator can sense a lower voltage from system demand and adjust as needed, then a smaller 10 gauge tuff wire is used to charge the battery. The smaller wire works fine because the battery can only take so much power when recharging and the resistance in the smaller wire keeps the battery from boiling over. Also I don't see a fuse in this system.
So what is the best way to hook this alternator up?
