68stang289
Just want to unload it so I don't have to move it!
New Ford Racing 289/302/351W Double Roller Timing Chain - $40
I picked this up new for my 1968 Ford Mustang 289 and never installed it. It came from Cloyes but has Ford Racing number M-6268-B302. It is brand new in the box with instructions. This is their race version where the cam sprocket is made from steel for maximum competition engines. Summit and Jegs sell these for $86 so save some bucks!
1969/70 Ford Mustang Driver Side Racing/Sport Mirror - $20
This came off of my 1970 Ford Mustang Mach 1 (will also fit 1969). The car was painted along with this mirror and it turns out I had two drivers side sport/racing mirrors that were painted so this one must go. It is in perfect shape. The glass is good with some normal very light minimal scratches in it (nothing major and it's not noticeable unless you are looking for it). It is currently disassembled. It doesn't have the remote attached but I have the remote linkage thing that I can throw in.
1969/70 Ford Mustang Deluxe/Mach 1 Door Panel Lights - $10
Pair of 1969 or 1970 Ford Mustang Deluxe/Mach 1 Door Panel Lights. There is some pitting on the chrome but the lenses are in fantastic shape. These would be perfect for a driver quality vehicle.
1965, 66, 67, 68 Ford 289/302 2 Grove Crank Pulley - $5
Took this off of my 68 289 Mustang to install a 3 grove pulley. This is two separate one grove pulleys that bolt together. They worked great together and I had zero problems. Casting number says C7OE 6A312C. In great condition. Should work for any 65, 66, 67, 68, or 69 Ford Mustang with a 289 or 302 or any Ford 289 or 302 motor. Please ensure proper fitment.
OEM New 1965, 66, 67 and 68 Ford 289 Crankshaft Harmonic Damper/Balancer - $40
I picked this up for my 1968 Mustang 289 and ended up selling the car before it was ever installed. It has Ford stamped into and is brand new. The number listed on it C82E6316 B1 1200. Should work for any 289.
1969-1970 Ford Mustang/Cougar Console Ash Tray - $3
Ash tray for a 69-70 Ford Mustang or Mercury Cougar Console. In great shape. The chrome around it is in nice shape. It needs to be repainted and the inside of it cleaned out a little bit. Otherwise in great shape.
70 LH and RH Fender Extensions - $10
These are off of a car that was a driver before. They have some dings in them but it looks like they could be worked out by someone.
69/70 (?) Fastback rear window boomerang - $5
This is the drivers side rear window boomerang that came off my 70. The two pins are still attached at the bottom and the chrome is in good shape. No pits to speak of but the chrome does exhibit some spider webbing on the lower part. Not noticeable until you are up close. I'm happy to send out a picture if it is helpful.
1967, 68, 69, 70 Ford Mustang Steering Box/Gear - $30 SHIPPED
Took this off of my 1970 Ford Mustang Mach 1 with manual steering. Should be a 16:1 ratio. Has part number C7ZR3550A, 9K29 and the tag reads SMB K 0A21B. It was in good working order prior to taking off. This price includes shipping to your door!
